1988 944
joemama's Avatar
Going the used engine route on my car. Today I "sold" the bad block currently in my car for $500. I plan on using that "cash" towards the removal of the "bad engine" I've found a few '88 engines and a few other "fun engines" along the way including a sweet S2 3.0 liter.
I might go with an '89 2.7 liter with the harness and brain box or I might stick with the '88, drop that in and call it good. It all depends on if I can swing a good deal for the 89 complete engine. Right now they are over $2K (no core) The records say it had just over 100K on it. The engine started right up, the compression test was 200 across the board and the leak down was solid. I found an 1988 for under $1,000 with 84K but the place is not Porsche experts. I think I was talking over his head when I called the place that has the engine and I'm not an expert.
In the end I didn't want to throw 1,000's of dollars at this problem only to have it come back and be in the exact same spot again in June or July.
It might be the stupid persons route but at least I'm moving in one direction now.
1988 Porsche 944 N/A Guards Red
2003 Honda Element (The dog box)
Old 12-02-2008, 07:05 PM
thekidd's Avatar
Send a message via AIM to thekidd
did they resurface the head while doing the head gasket job?
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 12-02-2008, 07:10 PM
1988 944
joemama's Avatar
thekidd
When I bought the car it had just had the head gasket service done. The original shop sent the head out to be milled. So yes, they did resurface the head, but not for a second time.
Why do you ask?
Old 12-02-2008, 07:35 PM
thekidd's Avatar
I didnt read all the posts, so not up to date with the situation. But if the car has ever over heated, hopefully not, the head will warp just a little bit. You can do all the head gasket jobs in the world and still have coolant leak in the engine cylinders and other places where it should not be.
Old 12-02-2008, 07:51 PM
Redline Racer
HondaDustR's Avatar
Did those '88 pistons get sold with the block, by any chance?
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 12-02-2008, 08:10 PM
1988 944
joemama's Avatar
No. I made sure I was able to keep the pistons.
Old 12-02-2008, 09:28 PM
Proprietoristicly Refined
John_AZ's Avatar
Joe,
Thanks for the update and cartoon
HondaDustR,
The "green" color of the coolant might be a sign that it is not the official "non-phosphate" coolant required in our cars. A couple of years ago when I changed my antifreeze to the Prestone non-phosphate it has/had a brownish/orange color.
It is now time to change again and it seems every brand can be used in ALL engines? The only change is the current "long lasting"-5 year or so brand. I will have to do more searching before I decide next summer.
John_AZ
Old 12-03-2008, 06:19 AM
Zero10's Avatar
The white residue on the outside of the cylinders shows it was not filled with phosphate free anti-freeze at one time. That said, nearly all antifreeze now is phosphate free, even most of the green stuff.
I just use prestone yellow, because it is available just about everywhere and its cheap (and phosphate free).
Buy my parts!
Old 12-03-2008, 06:54 AM
Prestone makes two types of phosphate free anti-freeze. One is called Dex-Cool Extended Life and is a reddish color. The other is just called Extended Life and is a green color. Both will say "phosphate free" somewhere on the label.
83 944 NA - daily driver
Old 12-03-2008, 10:56 AM
Redline Racer
HondaDustR's Avatar
IIRC, the prestone Dex-cool also indicated it was silicate free as well.
John_AZ, when you say non-phosphate coolant that's a brownish/ orange color, do you mean the Dex-cool, or was there yet another type?
Old 12-03-2008, 12:23 PM
John_AZ's Avatar
HondaDustR,
I had to look at the last bottle of antifreeze I used.
Yes Prestone Extended Life:
Q. Does PrestoneŽ Antifreeze/Coolant contain phosphates?
A. Some European automobile manufacturers request that a phosphate-free antifreeze be used in their vehicles. This issue is related to the extremely high mineral content of the water in Europe. If you were to mix an antifreeze that contained phosphates with the type of water they have in Europe, it may produce deposits that can settle in the cooling system and promote corrosion. However, in North America we do not have this type of water problem. Typical North American coolants have contained phosphates (which is part of the corrosion inhibitor package) for many years. Therefore, the question of phosphates is a non-issue here in North America. PrestoneŽ Antifreeze/Coolant is completely safe for use in both foreign and domestic vehicles.
For those consumers who would feel more comfortable using a phosphate-free antifreeze, our PrestoneŽ Extended Life 5/150 Antifreeze/Coolant is phosphate, silicate, and borate free. This coolant uses a special chemistry and technology that extends the life of the corrosion inhibitor package so that it lasts for five years or 150,000 miles (whichever comes first), and is safe for all cars and light trucks (old or new). PrestoneŽ Extended Life 5/150 Antifreeze/Coolant has been approved by General Motors under their DEX-COOLŽ specifications and is compatible with other DEX-COOLŽ approved coolants.
Information overload...
John_AZ
Old 12-03-2008, 04:12 PM
It was nice to find this thread. I am the new (and final?) owner of this car. The threads here really pieced together some of the puzzles I hadn't figured out going through the maintenance records. Great car. Bill - thanks for getting her back in good shape!
Old 08-29-2012, 03:05 PM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Porsche Crest
Awesome research.. go '88's!
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 08-29-2012, 03:35 PM
Woot! Haha. I was very happy to find Joe's posts. I got lucky, searching his full name and "Porsche 944" in Google. A photo of *my* car came up, with "(full name) Porsche 944" under it. Right to this thread. Which was scary at first... but it appears that all of the work has been completed.
I do wonder if Joe had nailed down where my oil leak was coming from... cam cover seals I think, was referenced in some of his old maintenance records that I now have...
The owner between the two of us replaced the AC compressor. This is damned near a new car! I may have some front end issues to address soon, as I have some uneven tire wear on the front right tire. Joe might have some insight as to that as well...
Old 08-29-2012, 03:48 PM
Tags
2.5 liter , 944 , engine , head gasket
