LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
Evil Genius
Rusty Heap's Avatar
Fixed my Crushed Oil line for $5 and a beer.
I had another post running for a while on how I was going to cut and solder in a slip on tube sleeve to fix the side oil line that runs up under the right hand jacking point to the front oil cooler. Previous owner or bone head shop in the cars history did the crushed tube, I found it while removing the side valence to put in new 28mm rear torsion bars in my 1982 911SC
I figured before doing major surgery and cut/solder, I might as well try the pressurize with air and heat the pipe with a torch to see if it'd pop out.
WOW, did this work slick. See my operatiing table, PVC fittings to plug both ends of the line, (1" caps) use lots of thread tape on the "fwd" end of the pipe and a 1" PVC cap threads on and seals fine. On the "rear" oil line fitting that has a flare fitting that goes into the thermostat, I used a short length of clear Vinyl hose, hose clamps, barbed to 1" threaded fitting, and another 1" PVC cap that I drilled and tapped for a Air Chuck.
Really small compressor set at 50 PSI, and a small propane torch. Started the compressor up and started gentle back and forth heating of the area, Nothing happening so bumped the air pressure up to 85 PSI, a bit more heat, and the major crushed area slowly started to expand into a round shape again. Bumped the pressure up to 100 psi, and the final creases except for the worst ones came out fine.
TOTAL HAPPY DANCE on my part, so I celebrated with a beer. Total outlay for my fix, about $5 in parts, about an hour or two of my time pulling off the oil line, rigging up the plugs, pressure/heat cycle only took 10-15 minutes, and the beer and happy dance was priceless.
Pictures of the operating table, then before and after of the oil line.
Life is a big ocean to swim in.
Wag more, bark less.
Old 04-13-2008, 07:22 AM
rsrfan's Avatar
Very, very cool. I am going to try that.
JP
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 04-13-2008, 07:30 AM
Great job, and thanks for the details on how you did it!
Brian
'82 SC Targa
'83 SC Cabriolet
Old 04-13-2008, 07:59 AM
DanielDudley's Avatar
Nice job.
Looks like that crease was made by a Sears Craftsman 2.5 ton jack, circa 1986.
Old 04-13-2008, 12:27 PM
mca mca is offline
mca's Avatar
Nice work. I am sure this will help TONS of people. Thanks for sharing.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 04-13-2008, 12:31 PM
Looks effective!
Lets see, highly pressurized vessel, flammable liquids & gas, fittings of questionable integrity, and fire. Sound like fun.
Please concider safety gear when attempting this at home! Might what ear plugs to and to make sure the oil and solvent is out of it.
That thing may be a potential bomb while working on it...
I'd try it...
Old 04-13-2008, 01:02 PM
MEMBER # 930
waynesco1's Avatar
nice work ! Only one beer ? I will keep this in my bag of tricks !
Old 04-13-2008, 02:06 PM
brads911sc's Avatar
Wow. Nice.
Old 04-13-2008, 04:01 PM
vash's Avatar
great job, but i think that was kinda dangerous. cal osha limits how much we can pressure test our prestress ducts, to 25psi. i have seen guys go higher, and they go off like bombs.
poof! gone
Old 04-13-2008, 04:04 PM
theclaw's Avatar
Cal OSHA....'nough said. Anybody use compressed air to pop a caliper piston?
Like there's not enough spinning belts and pullies when I check the oil!
Nice work.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 04-13-2008, 04:13 PM
Evil Genius
Rusty Heap's Avatar
THANKS guys, I really appreciate all the kudos.
I've learned many many tricks from you all also, and try to "pay back" the masses.
Lets see, safety gear did consist of me wearing safety glasses, the line had been flushed with solvent the night before and left open, I did start at 50 psi not 100+, there WAS a bunch of blow-by air past the threaded on "forward" cap seal so the fresh clean air passing through the cap was purging any fumes/vapors, and if anything I call the pvc cap a pressure relief valve if it popped off.
Lets see, a 1" diameter pvc cap might have about 1.75 sq inches of area and we're only talking then less than 150-175 pounds of air force on a cap that may weigh an 1/4 ounce max (gads, can you tell I'm an engineer?) so even if it did pop off..........oh the horrors, oh the humanity of it all.....
So to close, no p-car parts or owners were harmed in filming this event.
Cheap tricks like this make Pelican forums ROCK,
THANK YOU WAYNE for your own special tip of the hat. Your web service makes this all soooooo worthwhile and possible.
Old 04-13-2008, 05:40 PM
Less brakes, more gas!
euro911sc's Avatar
WOW, thats and ugly thumb... um I mean great job! Good wiki material!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-13-2008, 06:17 PM
What, no pic of the beer...or the happy dance? Ok, you can skip the happy dance pic.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 04-14-2008, 07:01 AM
Again great job, sent it to my shop and he likes it.
No, this is not in the same class as welding on a gas tank that still has gas in it.
Of most concern is somone having oil or solvent present in the line and under 100psi. Then adding the heat and having ignition.
You knew not to do this.
However, having the plastic pop could hurt to.
I have done risker things but don't usally know it is the case untill after.
Old 04-14-2008, 11:00 AM
rnln's Avatar
Dave,
do you heat it up until red hot or just hot is enough?
Thanks.
Fat butt 911, 1987
Old 04-14-2008, 11:49 AM
Bill Douglas's Avatar
Good skills Dave.
An excellent donation to the pool of skills.
A quick side question; your '82 engine with SSIs (and CIS?) how much of a difference did it make going to a 20/21 cam grind. And where is the power happening?
Old 04-14-2008, 12:14 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
Red face Safety First
If anyone else tries this PLEASE be sure you thoroughly rinse all the oil from the tubing & fittings using a good solvent.
A blast housing, e.g. doing this inside a very sturdy piece of pipe, is also a good idea.
I have personally seen a similar wall thickness tube explode from the combination of oil & O2. Yes, that was pure oxygen & not air, but the risk is there.
Wayne, if you include this as a suggestion via a Wiki link, be sure to put in safety disclaimers so Pelican doesn't incur any potential liability from recommending something like this. Even if combustion doesn't occur, a weakened tube or one with small cracks, combined with excessive pressure, could make shrapnel.
FYI, it was not unheard of during WW2 to have fatalities caused in diving training by the old-style oxygen tanks - remember this is in pre-scuba days - and the fittings not thoroughly cleaned of oil. Pure oxygen + oil, while someone is breathing in. Lungs exploding are extremely messy, I've heard.
Yes, it may be a sea story told by an old CPO, but it still makes one cautions.
Old 04-14-2008, 01:44 PM
dtw dtw is offline
GAFB
I thought I heard a version of this repair that involved filling the line with water, which avoided the explosion issues and helped with more even heating of the pipe?
Several BMWs
Old 04-14-2008, 02:07 PM
I have done a few of these, I use water pressurised by a stirrup pump. Then warm up with oxy acetylene. 100 percent success, no fatalities.
Old 04-14-2008, 04:47 PM
