What is a jumper?
I understand to set idle speed correctly you need to by pass the ICV by jumpering test ports (B & C). This might sound silly, but what is a jumper? Is it just a peice of wire or is it a tool you have to purchase. If it's just a peice of wire, what guage should it be? Thanks.
Mike '84 911 Carrera Coupe (totaled) '83 911 SC Coupe ‘06 Aston Martin Vantage V8 |
A piece of wire. Normally the same gauge or larger than the wire connected to the pins you "jumper."
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Irrationally exuberant
That picture looks familiar.
![]() A "jumper" is just a wire used to make a (usually) temporary connection. Usually there is something on the ends to facilitate connection. A jumper for the fuse box would have alligator clips on the ends for example. A jumper for disabling an alarm would have a of spade connectors on the end. ![]() -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 10-24-2004 at 11:11 AM.. |
Registered abUser
A suicidal man atop the Empire State building.... oops, wrong kind of jumper.
Got it! Thanks.
