wrench
Winter tuneup
I wanna Live 'til I die!
...that's a little more elaborate than my winter tune-up... but not bad, not bad at all!
Thanks for sharing, I think you are qualified as a nutter for this board now! Welcome... If you are bored - being that you are done and all... I can send you my bike!?
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
unsafe at any speed
Wow! Great job on realigning the tranny to the engine with off setting the dowels!!
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
splines
I bet those splines will wear even now. To bad BMW suppliers don't hold the same specs. I know a guy with a 04 Rockster with 15,000 miles and the tranny input splines are worn off. Image them letting go out on the Highway. He was lucky , it happened at a stop light.
Another guys BCR (04) Hall sensor was intermittent. He was on the Highway and almost was run over. Scary stuff
LT |
Uh....who me?
Great #2 post Patrick! Where do you live? Can I stop by?
![]() Do you have a suggestion about how to clean up the heads on the inside without taking them somewhere to blast? I've got some Ducati heads that could use some of that. I'd prefer to use something that doesn't require changing out the valve guides. Thanks.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Ah, Bob... once you have the heads off, you may as well change the guides and do a wholesome job... it is not THAT much more work, but it will add some extra "insurance" if you will...
I'd be careful with blasting them... that can create all sorts of issues.
Patrick,
Pull those rods and have them balance and install new rod bearings. If you are going to reuse the pistons have them balanced too, better yet get SJBMW 12:1 HC pistons. Even if you don't port the heads at least match the throttle bodies to the rubber mount and rubber mount to the heads. Great pics and great job on the rebuild. Philip "It's a great bike but I can make it better, then blow it up and then make it better again". 04 R1100S BCR # 195 03 R1100S BCR #44 R.I.P. new home with 'onekiwi' 1150 cc cylinders 12:1 SJBMW pistons BMW 36 mm intake valves Ported and polished heads (just a little) '07 R1200R cams TBs bored +3 mm Throttle bodies matched to rubber mounts matched to heads SJBMW Exhaust Accelerator Kit (modified) Exhaust pipe welds ground down Laser Exhaust Laser 2 spark Chip InDuct SJ PowerFilter K's 3.5 bar regulator Ohlins Sargant Seat Spiegler SS Brake Lines LED tail/stop light and turn signals Aux Fuel Tank (6.8 gallons total) |
Great photos and interesting curved wear on the splines.
Thnaks, RB |
Banned
Fasterpatrick -
Great set of procedures. Thanks. Gotta make space for a lathe in my shop. With that degree of wear on the spline, do you think the wear could be detected shaking the rear wheel in a high gear or is there just too much normal tolerance between the wheel and the clutch? Can you feel it through the gap with the starter motor removed? Any way besides tearing apart? Your comment about Honda Moly grease: are you saying there is wear despite the visible residue of that grease? Or any grease? Does that leaves Mercury Green grease last grease standing? Thanks. Last edited by Peter Parts; 12-23-2007 at 12:37 PM.. |
Underwater basketweaver
Wow... just WOW!
'05 R12GS '08 HP2 Sport '16 GT4 |
wrench
When you're done with that step, let the head cool a bit so you can handle it, then blast it with baking soda. You wouldn't want to use sand or glass beads, because you'll never get all the abrasive out. But with baking soda, when you're done, just wash the head in soapy water and it all dissolves and washes away.This is the gun I used for that: http://www.thetoolwarehouse.net/shop/UNI-007.html As far as using something other than a torch and baking soda blasting... *shrug* scrape it out and use some carb cleaner on the rest I guess. But you're not going to get it as clean as with a torch and baking soda. Quote:
And yes, that was my point about the Honda Moly 60. I cleaned the splines of the disk and shaft, used a brush to evenly coat them with moly, and you can see the wear in 23k miles. So I think lack of lube or quality of lube is not the root problem here. Patrick |
Uh....who me?
Well since I don't own a torch and have never used one and these are good heads I guess I'll just clean 'em up with plan B. Thanks though.....was wondering how you got them so nice.
Walnut shell use to be a very popular blasting medium for blasting inside engines. There has been a lot of dry ice blasting for paint removal, but could be an effective blasting medium as well.
Both would eliminate the reside issue.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
Interesting work! How was the indicator stand trued to the crank centerline? (I'm no machinist).
best, Dave 99 R11S |
wrench
It doesn't have to be trued to the crank. All it has to be is solidly attached. Spin the crank, and the stand spins in a circle with it. The indicator follows a circle too, and if that circle is concentric with the bore you're trying to measure, all is happy and the indicator reading doesn't change all the way around. If it is not, the indicator will tell you how far out of line the two are.
And something I did not take into account when I first did this, was the crank to main bearing clearance. Someone on the ibmwr tech list pointed it out to me and I had to go back and take the measurements again while wobbling the crank around in its bearings, then move the bushing inserts again. So it was a little more work than indicated in those photos, but still, stock it wasn't lined up. But the difference was more like 3 thou than 5 thou. |
Banned
But once the hard parts wore down 3 or 5 thou, wouldn't they then be sitting pretty?
There's a ton of slop in there, just in the rear end, much less the transmission. Not impossible, but not anything well quantifiable. > But once the hard parts wore down 3 or 5 thou, wouldn't they then be sitting pretty? Jeez no. That's just more slop and more misalignment (albeit possibly slightly slightly less binding) and thus still more wear.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Living on borrowed time!
bob hancock:
a soda blaster from eastwood (www.eastwood.com) is the ticket for easy carbon removal. I just bought the gun (it's different for soda than for other media) and use my existing tank. If you do the ports consider extrudehoneing them (http://www.extrudehone.com/)
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
btw, I've used soda in a cheap generic small handheld regular media blaster from harbor freight to very good results. A purpose built one with smaller jetting might be better, or maybe run longer on the same amount of soda, but a regular one works very well. great for carbs, and really old vintage and brass fittings.
I've never had luck with Walnut media. I've tried two different grain sizes with a bunch of different orifice sizes in a pressure blaster, and have never gotten by w/o nearly instant clogging. If anyone has had better luck than me and could tell me how I'm messing up, I'd be glad to hear it.
Uh....who me?
