Anti-lock brakes
How can I tell if I have anti-lock brakes?
I just bought the car - it's a 1988 with 17K miles on it and it's been sitting for 6 years (covered in a garage).
When looking at the fuse panel, I noticed that the spot that is supposed to have a relay for anti-lock brakes is blank.
Just wondering where the control unit is located and what it looks like.
Thanks.................Vern
Old 01-15-2007, 04:41 PM
74goldtarga's Avatar
I had this unfortunate experience and I discovered all the other abs parts absent as well. There is something like a box or a valve that is supposed to be in the passenger footwell. There should also be wheel position sensors (different than the brake pad wear sensors) visible if you take a wheel off. I can maybe get you more info later. I'd bet you don't have it if you don't have the relay though.
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 01-15-2007, 04:49 PM
Thanks for the info. It doesn't really matter to me ir there not there but I thought that all 1987 & later cars had them. This car also doesn't have air bags which I thought were standard on 1988's - oh well.
Old 01-15-2007, 05:00 PM
That Guy
Techno Duck's Avatar
Passenger side footwell, there should be a rather large box on the right side.
You can also check the option codes in the spare tire well, option 593 is ABS. You can also do about 30-40mph and jam on the brakes, thats the easy way to find out.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-15-2007, 05:19 PM
I thought 87 and later had ABS and airbags as well, based on Excellence Magazine last summer which stated that they all do, not so.
Old 01-15-2007, 05:52 PM
Razorback1980's Avatar
My 87 has neither. I'm thinking they thought an automatic doesn't go fast enough to need either!
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-15-2007, 07:48 PM
Gon fix it with me hammer
svandamme's Avatar
my 88 has it, and it's listed as an option it wasn't default.
593 ANTIBLOCK SYSTEM (BOSCH)
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-18-2007, 11:10 AM
Non Compos Mentis
Re: Anti-lock brakes
Get up to high speed and slam on the brakes. If there is lots of smoke and noise, you do not have anti-lock brakes.
Old 01-18-2007, 06:00 PM
Custom User Title
Dave L's Avatar
My 88 has niether, I think it ABS and airbags were available as an "option"
Old 01-18-2007, 06:18 PM
ABS was an option on the 88 Turbo (i thought it was standard too, till i turned on the motor of my 88 turbo and didnt see the light), but was standard on the 88 Turbo S, 89 NA and 89 S2.
Airbags were standard on the 87 and forward turbos and all S2s.
Old 01-25-2007, 04:52 AM
svandamme's Avatar
Re: Re: Anti-lock brakes
or simply look for the controlbox on the right side of the passengers footwell
Stijn Vandamme
Old 01-25-2007, 04:58 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Flat spots on the tire FTW!!!
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 01-25-2007, 05:17 AM
Schumi's Avatar
My 87 24S definitely does not have ABS. I do not personally like ABS... it just makes life more appreciable when you *don't* have it.... :-)
M
Old 01-25-2007, 05:43 AM
svandamme's Avatar
same here, don't like power steering either... or powerbrakes that are to "powered"...
i disconnected abs on my S completely ... unplugged the brain
then connector T40 to kill the warning light...
Stijn Vandamme
Old 01-25-2007, 05:47 AM
x2
My cars for sale, due to move
1986 944 turbo - For sale.
1987 944 N/A - For sale.
Old 01-25-2007, 06:35 AM
I've been looking for the T40 connector to trace the indicator light, stop light power.
Would you mind telling where it is? Thanks.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 01-25-2007, 08:13 AM
svandamme's Avatar
it's a flat connector, an inch wide, should have one white wire on the end of one side, and should dangle somewhere on the top left of the passenger foot well, above the motronic brain...
Stijn Vandamme
Old 01-25-2007, 08:22 AM
Thanks.
Old 01-25-2007, 12:25 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
My '88 has neither ABS nor airbags.
nate
1988 944... and a bunch of other cars
Old 01-25-2007, 02:25 PM
T40 connector
Sorry to hijack but I need to make sure.
Is this the one Stijn?
Old 01-25-2007, 02:29 PM
