993RS brakes
993RS
front rotor: 322x32, 20.5#, 2 piece(lighter al. hats are available) front caliper: 4 piston, 36/44mm pistons, 151cm^2 pad area/caliper, 8,3# ![]() rear rotor: 322x28, 18.2#, 1 piece rear caliper: 4 piston, 30/36mm pistons, 125cm^2 pad area/caliper, 8# ![]() pads, from back RS/tt front, RS/tt rear & 993 n/a front(same pad), 993n/a rear ![]() calipers bottom c/w, RS/tt front, tt rear, RS rear, pads from bottom left c/w RS/tt front, RS/tt rear & n/a front, RS/tt rear & n/a front, n/a rear ![]() front RS rear 30/36, back tt rear 28/28 ![]() n/a front rotor left RS/tt rotor right ![]()
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 01-01-2008 at 06:52 AM.. |
Bill,
What makes them different than Big Reds? I don;t recall the Big Red rear rotor size, but it looks like th eonly other difference I can see is the 36/30 rear pistons instead of 34/30. Man those would be great.
1985.5 944 GTS |
Sports Purpose 911 Driver
Wow! Bill you are G-R-E-A-T at spending my money ;-)
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
993RS and 993tt front front rotor: 322x32, 20.5#, 2 piece(lighter al. hats are available) front caliper: 4 piston, 36/44mm pistons, 151cm^2 pad area/caliper, 8,3#, largest body the back is where things vary a lot 964t rear 964t use a 299x28mm rotor, 30/34mm 4 piston, smallest body caliper, 6.5# w/o pads, pad area 86 cm^2/caliper 964RS rear 964RS use a 299x24mm rotor, 30/34mm 4 piston, smallest body caliper, 6.5# w/o pads, pad area 86 cm^2/caliper. 964t and 964RS rear calipers are not the same because of the rotor width 28mm vs 24mm 964n/a rear 964 n/a use a 299x24mm rotor, 28/30mm 4 piston, smallest body caliper, 6.5# w/o pads, pad area 86 cm^2/caliper. This caliper has the narrow 24mm throat and smallest pistons. 993n/a rear 993 n/a use 299x24mm rotor, 30/34mm 4 piston, smallest body caliper, 6.5# w/o pads, pad area 86 cm^2/caliper. Same small body narrow throat as 964 n/a but w/ the bigger pistons. 993tt rear 993tt use 322x28mm rotor, 28/28mm 4 piston, medium(actually barely smaller than Big Red front by 10mm in height), 8#w/o pads, pad area 125 cm^2/caliper. 993RS rear 993RS use 322x28mm rotor, 30/36mm 4 piston, medium(actually barely smaller than Big Red front by 10mm in height), 8#w/o pads, pad area 125 cm^2/caliper. The 993tt and 993RS rear caliper uses the same pads as a 993n/a front i.e.the same medium large body but w/ axial mount ears rather than the 993n/a radial mount. The only difference between 993tt and 993RS rear is piston size 28/28 vs 30/36. This piston difference arises from the AWD vs RWD configuration of the cars. Here is a pic of a 964t, small body caliper(left) and a 993tt, medium-large body caliper on a 309x28 930 rotor ![]() here is a pic of the 3 different size pads, from left large 993tt/RS 151cm^2/caliper, medium-large 993n/a front & 993TT/rs rear 125cm^2/caliper, small 964t & 964RS & 993n/a rear 86 cm^2/caliper ![]() clockwise from top right; 993tt, 965t, 911M, 911A ![]() on left 993RS rear, on right 993RS front, the pads are the same length and thickness but the front is ~10mm taller ![]()
I have brake envy...
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
you guys don't need this stuff
just posting a FYI because of recent questions and confusion
MBruns for President
mmm brake porn - what a great way to start 2008!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Bill so is there a PV to handle the larger rear brake calipers on the RS?
1985.5 944 GTS |
ABD/LSD cars have 2, that includes all the AWD cars others have 1 n/a is 40 bar x1 RS is 40 bar x2 n/a AWD is 45 bar x2 tt is 55 bar x2
Bill you mention there is a lighter rotor advaialble for 322x32 front rotor (which my car has) i am planning on updating the front caliper to 928S4 spec in the near future as well.
can you share the part # (or supplier) with me? i would love to have a lighter solution for the rotors (front and rear)
... 59 356a Coupe .... .... |
The 993RS/tt rotor can be lightened by using an aluminum hat. Wrightwood racing used to have them, Chris Walrath has made some for either himself or a select few.
Other than that, AP makes a slotted 322x32 which will require a custom hat. I believe that CDOC is selling them now but the usuial distributer in the US is Essex in Ga.
Sure, I don't need it, but that doesn't stop me from drooling like my Great Dane at feeding time.
Bill, Do you have a source for the rear RS calipers? What sort of price could i expect to pay for a pair?
Steven 1995 - 993 RS Tribute - 4.0l Engine plus other stuff... 2005 - Touareg V8 Tow Vehicle |
993 352 425 80 left caliper 993 352 426 80 right caliper Pelican shows just under $600ea
Bill,
Sorry for the late thank you, but THANK you. Regards
I currently have a 993 set-up on my car. I also have a 993TT big red set-up of calipers and rotors, and am considering changing the rear calipers to the RS. Or should I stick with the 993 rear which has bigger pictons than the TT rear? So, Can you explain the potential PV change(s) going to the all 993TT, 993TT front 993 rear, as well as to the RS set-up? Thank you much, your knowledge is greatly appreciated. John
1985.5 944 GTS Last edited by North Coast Cab; 01-17-2008 at 01:13 PM.. |
Rear bias is not just a function of piston sizes. Rotor diameter and pad choice also have effects.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 01-31-2008 at 04:15 AM.. |
Wheels are still turning.
993NA Brake Option Summary Option #1 F - 993 NA Calipers 36/44 & Rotors 304x32 R – 993 NA Calipers 30/34 & Rotors 299x24 PV – 40 #? Option #2 F - 993TT Calipers 36x44 & Rotors 322x32 R – 993 NA Calipers 28x30 & Rotors 299x24 PV – ? Option #3 F – 993TT Calipers 36/44 & Rotors 322x32 R – 993TT Calipers 28/28 & rotors 322x28 PV – M220 ? Option #4 F – 993TT Calipers 36/44 & Rotors 322x32 R – 993RS Calipers 30/36 & 993TT Rotors 322x28 PV – 40 #? Questions: 1) Is a 993NA rear caliper and rotor a better option than a 993TT rear caliper and rotor when a 993TT front caliper and rotor is used? Larger pistons, smaller rotor. 2) The 993TT and 993RS appear to have a different M/C than the 993NA, is this an issue that would need to be addressed as well? 3) Also, I can’t seem to find the P/V’s in PET in order to clarify the part numbers for each system. Thanks, John
1985.5 944 GTS |
Bill,
Another question for you... How would the combination of 993TT front calipers and Rotors go with 993na Front calipers on rear with 993TT Rotors. I understand the piston size would be the same front and rear and that the caliper for the rear would require an adapter. your thoughts? Regards
