My vents constantly blow hot air? why
What isnt functioning properly that constantly blows hot air into my 944 n/a 87' cabin. Thanks Josh
1987 944 n/a |
That Guy
Plastic clip is probably broken. Search for 'plastic heater clip' and a multitude of threads will turn up.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Also check your Brake Booster Check Valve. There is a tiny port and the vacuum line that connects to it controls the heating system. I accidently broke mine well wiping down the engine and my heater was stuckl on until I fixed it.
Vern
Check you heater control valve. Part number from our host.
944-572-085-02-M53
79SC, Wevo Shifter, SSI, Koni's, MK Muffler 85 944 Stock Past Porsche's 87 944 87 928S4, I was young and dumb 99 Boxster 70 911T |
Non Compos Mentis
Stick your head under the dash, towards the center. If there is a little shaft dangling, it's because the plastic clip that holds it to the hot/cold mixer valve broke, leaving the valve in the full hot position. The clips are getting brittle by now.
I had the same problem in my 944 n/a 1/'85. Turned out to be a faulty heater control valve. The valve was worn and would not completely shut off the hot water/fluid going into the heater, thus the heater radiator (or heat exchanger) was permanently producing hot air .
Bought a new valve from our host, replaced it and the problem was solved.
Max Hofer 1985 911 Turbo-Look 1985 944 NA Santiago - CHILE |
928-574-573-03-M53
Trying to work for parts!
wrong area.
86 Metallic Grey 85.5 Metallic graphite - Gone |
Super Moderator
+1 on the heater control check valve.
