Windshield Washer Hose Diagram?
I want to get my '65 coupe's windshield washer system going and have repaired the pump but I can't figure out the layout of the hoses and fittings. The old hoses, etc. were lying in the smuggler's box and it seems there are more pieces than necessary. There is a single outlet from the washer reservoir and then "in and out" nipples on the pump. It would seem that a hose should run from the pump to a tee and then to each squirter and that would be all that's necessary but there are several more old hoses and fittings than that. I've looked for a diagram through Porsche USA, Stoddard's, Pelican Parts and the Pelican forum search without success. I'd sure appreciate some help.
Jerry Weiland
'65 911 Coupe (301278)
Old 06-19-2008, 12:43 PM
AutoBahned
RWebb's Avatar
my '73 hose runs along the D. side fender well - some cars have L shaped plastic connector just under the Pass. side squirter
at some year, the L & T connectors also have anti-backflow valves and filters
Old 06-19-2008, 01:10 PM
The closest thing I could find for a layout was the PET diagram
Old 06-19-2008, 01:11 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep. That's about the best you'll find. Here it is.
Kevin L
'86 Carrera "Larry"
Old 06-19-2008, 01:19 PM
Excellent! Many thanks to Bluesky and Kevin. Just what I needed. BTW, what is a PET diagram?
Old 06-20-2008, 06:50 AM
