911 SC Headlight Washer Relay
I needed to do a little R&R on my air dam and and since the bumper was off, decided to get the Headlight Washer system working. The pump was shot as was the relay. I've got the new pump and while looking for a replacement relay find that it's an $85 or $90 dollar part. Can anyone suggest a suitable alternative that's a little more affordable?
Thanks Chris
82 911SC |
Recreational User
Maybe the broken relay can be repaired - it might only require a little soldering.
Can you post pictures so that the rest of us can follow ( I need to do mine as well)
Thanks lorne M.
83 SC |
83 CHECKER
$90 to keep everything working is a small price to pay, I am doing the same thing and quite frankly it is one of the lesser amounts I have ever paid to resolve a problem that I want restored to the way it is suppose to work.
'83 911SC CAB '90 ZR-1 '68 TR-250 |
You guys do know that the lights has to be ON in order for the headlight washer to work.
LOL Newbies Last edited by ruf-porsche; 01-17-2009 at 06:11 PM.. |
Hey Ruf,
Yes , the Lights are on and there is power going to the relay. The problem is that the relay is not switching and putting power out to the pump. Do you have any insight as to why that may be and what can be done? If I've got to drop $90 on a new relay so be it, I was hoping someone here had found an alternative. Thanks for your help. Chris
82 911SC |
A second on the request for pictures. This is something on my To-Do list too and it would be nice to have some idea beforehand rather than the usual "voyage of discovery" that so much off my 911 tinkering entails
As far as relays goes aren't they a pretty common Bosch part? Even then any 12V auttomotive relay ought to be able to work as long as its not mated with some sort of specialized connector block. Thanks
'83 SC Coupe Last edited by DavErb; 01-18-2009 at 04:28 AM.. |
You have power to the relay, but do you have power to activate the relay? One wire should always be hot, but another wire should be hot when the headlights are on and the washer switch is turn on. That is the control wire to activate the relay. You can purchase the same relay for a lot less money, but it would be inappropriate for me to tell you where, since the host of this forum also sell the part. Do a little research. Here's a picture of the relay. ![]() |
Somatic Negative Optimist
Porsche used a lot of Bosch relays, is it black and square?
Just noticed the pic by ruf, Hella is good. Reinigungsteuergerat = Cleaning-Control-Devise. The relay should show the rating on it, 5WD? I am used to Amps. Looks like 5-pin. Take it to an Auto supply, they'll find a replacement. While you're at it, get a spare relay for the Lambda brain under the pass. seat. ![]() Use dielectric grease on the pins.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() Last edited by Gunter; 01-18-2009 at 05:17 AM.. |
Thanks again
I have power to activate the relay, it jsut won't switch over. It's interesting though, the part I have is different from the one you are showing. Chris
82 911SC |
Post a picture of your relay. The relay I posted is the 80-90 bucks relay. 928 618 111 00
Hello. / Big Bump
![]() Does anyone have the electrical schematics for the headlamp washers? I too would like to check mine cheers. |
What year is your P ? I have most of the schematics Sent from my iPhone using Tapatalk
__________________ 1985 Carrera 3.2 |
SRA = ScheinwerferReiningunsAnlage (1 word !) = Headlight washer system Option code M288 ![]() - the F5 connection point is to the light switch, terminal 58 where it get the power for the electronics (so, yes, lights should be on to use it) - the M57 is to the tacho for some reason - MP I is the ground connection up front where the battery negative cable connects to the bodywork. You can see that the power for the motor comes from fuse 3, 25A that is also the fuse for the 'cabrio verdeck'. Happy testing
Hi, yes sorry should have said, I have a 1980 SC
I understand many of the guys want everything to work as designed, or better. I am the same way, and all the functions on my 85 work as designed, or better.
That said, the headlight washers are neat, but likely the least used option on any 911 except seat heaters in a Miami, FL 911. My headlight washers do work, but they will hose down the entire car. In fact they work as a backup if the windshield squirters fail. In the 26 years and 100,000+ plus miles of driving my 911 in 41 states and Canada, I have actually really needed and used them once. Light rain in Utah, and all the feeder roads to the highway were dirt, or mud roads. Every vehicle that came to the highway brought mud and the rain made a mist of brown goo and the car and headlights were covered in brown layer of mud. I used over a gallon of washer fluid that day.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
