Woodland Hills, CA
Need tips on Hood Shocks
I am just about to embark on my first experience at changing out my hood shocks/struts. I'm tired of the prop stick that always gets in the way when performing work under the hood. After performing a search on the subject, I only find threads of everyone complaining about the job. But no real advice, tips or how tos in getting the job done with the least amount of grief. It appears that the fuel fill pipe is limiting the work space on the drivers side. Oh, and I have a 72 T. Any advice would be appreciated. Thanks
Old 02-09-2009, 07:10 AM
Actually, some of the most recent threads offer a great tip--a long hemostat. I'd suggest a bit of practice pulling and replacing the pin and safety with either a thin pair of long needle-nose pliers or get a long hemostat (don't know where but they are available). Everything else in the replacement is obvious and straight forward.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-09-2009, 07:31 AM
Zeke's Avatar
And don't worry so much about the little clevis pin. The lift pin will stay on it's own due to constant pressure. You have to raise the hood to the point of just starting to bind to get the pins in. 2 people makes this a snap.
Old 02-09-2009, 07:51 AM
gtc gtc is offline
abides.
gtc's Avatar
Having a second person to hold the hood while I inserted the pin was helpful for me. If they have small hands, even better.
Old 02-09-2009, 07:55 AM
Administrator
Jack Olsen's Avatar
A hood strut means never having to scrape your knuckles again.
Old 02-09-2009, 08:04 AM
vash's Avatar
hemostats, and a friend.
poof! gone
Old 02-09-2009, 08:09 AM
scottb's Avatar
Some people of said that it's a good idea to tie a thread to the pin before trying to install it. That way, when you inevitably drop it, you'll be able to easily retrieve it and try again.
HTH.
1984 Targa
Old 02-09-2009, 08:11 AM
Pre Registered
tchanson's Avatar
As noted above, a cheap locking hemostat makes the job on the driver's side in particular a snap.
Available here:
http://www.sciplus.com/search.cfm?utm_source=internal&utm_medium=search&utm_content=cf&utm_campaign=celsearchtest&formfield1234567891=0&formfield1234567892=11&formfield1234567894=&term=hemostat&btnHand.x=0&btnHand.y=0
Tim
Old 02-09-2009, 09:19 AM
bdisco's Avatar
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
The string / thread + pin idea sounds like a great one. The hood struts are on my "to do list" this spring. Thanks.
'88 Carrera
Old 02-09-2009, 10:18 AM
ths911's Avatar
Did mine 2 weeks ago. got the hemostat from Harbor freight. I also used dental floss tied to the small peices so when I dropped them - and I did - they were easy to retreive. Then cut off the floss after I was done.
take your time and you'll be OK.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=94952
1987 Carrera Coupe
Old 02-09-2009, 10:26 AM
"O"man(are we in trouble)
widgeon13's Avatar
The above is the best advice you can have, just take your time and don't get stressed over the thing. Use the dental floss and not string.
Old 02-09-2009, 10:32 AM
burgermeister's Avatar
I'm with milt - screw the clip on the driver's side. My car didn't have one, so someone before me had the idea too. I haven't had the pin move yet.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-09-2009, 12:02 PM
Woodland Hills, CA
Thanks to everyone for their input. If nothing else, I have gained some confidence, although I think I threw away all of my roach clips from the 60s.
Old 02-09-2009, 06:32 PM
efhughes3's Avatar
Save your money and time:
Buy the Seinesystems hood "stick"-looks slick, works slick.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-09-2009, 07:02 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Hey,
Just did mine today, 1975 911S, everything above applies. I used a nylon strap around the rafters to hold up the hood(the dog didn't help at all). Took about an hour, using the OEM ones I bought on eBay.
Cake job!
eric
Old 02-09-2009, 07:03 PM
Banned but not out, yet..
RSBob's Avatar
I did mine today as well. I parked the car into a 63 MPH headwind (constant) which kept the hood up - but had to be quick to duck when it dropped below 45. I then suspended myself with the assistance of a climbing harness upside down from my apple tree. Dressed in full surgical garb, and using a robotic arm, a piece of dental floss (unwaxed) I guided the inverted arm in 23 degree maneuver.... and dropped the cletis pin... until I dressed in my magnetic suit.... and it was just that easy!
Old 02-09-2009, 07:26 PM
rgrimm's Avatar
I can do the '68...the '84 is a nightmare.
So I took the cowards way out on the filler-neck side. I discovered that a replacement interior door hinge pin was the correct diameter and, from the inside (not the fender side) inserted it through the hole as far as it would go.
It's not going to work itself all the way out!
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 02-09-2009, 07:45 PM
I paid the local porsche expert the fee to install mine while getting some other work done
Hey, we need to jump start the economy.
Brad
1983 911 Cabriolet (daily driver)
2000 ML 320 (Shared by teenagers)
2005 Pilot (Wife's)
Nickatnyt's Avatar
I was going to do that until I was quoted $300 just for labor.
Uh.....NO
1982 SC...Guards Red + Linen
Old 02-09-2009, 08:55 PM
Uh.....NO
I purchased the shocks from out host and labor was well under $100
Brad
2005 Pilot (Wife's)
Old 02-09-2009, 08:59 PM
