Oh oh, found another rust problem: Pics
When notching the tub for my front oil cooler I came across some more rust. I have a few questions for those who have done this or know body work. Since the rust isn't in a major structural location I was wondering how to repair this. Can I just take it down to the metal, remove rusted out parts and fiberglass in where the hole is? Should I cut the piece from the car and graft in another piece from a dismantlers? Finally, what about repairing with a piece of sheet metal stock and crudely hammering it into shape?
Also, since I'm putting on F-Glass bumpers, I won't be using the bumper shocks or mounts, can I drill the spot welds on these and remove them making my rust repair job easier and shedding a little (albite not much) weight from an outter corner of the car? Or are these minor/major structural pieces?
Here are the pics of the dammage, not for the faint of heard
1978 911SC 3.0 (former)
a_roseneck@hotmail.com
Old 01-23-2004, 12:14 AM
Oh yeah, I'm not concerned about the brackets that hold the washer tank and the horn because I'm relocating both, not sure where yet but I'll figure it out
Adam
Old 01-23-2004, 12:15 AM
I thought the brackets were structural? I started removing the one on the drivers side after I pulled out the windshield wiper fluid tanks and after looking at it for a while I decided it wasn't a great idea. But I have no clue other that my opinion. AND.... your car has NO rust! SC's do not rust!
That is a dirt collection spot. Both corners with tanks hold a lot of dirt. Thats why I pulled the useless bottles. Nobody really knows whats lurking until the car looks the way yours looks now, apart.
I've decided to leave the oil tank even though it is a dirt collector.
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 01-23-2004, 04:45 AM
3.2 CAB's Avatar
It looks like the battery had leaked out there. If I were doing it, I think I would leave the brace but cut out the rot, and mig in some fresh steel there.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-23-2004, 05:08 AM
Isn't that bumper shock area one of the stupidest designs Porsche could have come up with? If I were you I would cut out the rusted area and form some sheet metal and butt weld it in. If you want to delete the reinforsement go ahead. I pesonally wouldn't. I would weld a top on the reinforsement after I fixed the rust
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 01-23-2004, 05:35 AM
I just replaced the front suspension pan because of battery acid related rust. The area in the picture is a little high for that kind of rust, but I would take a look at the front suspension mounting point on that side as well as the area under the battry tray. That doen't look like dirt accumulated rust.
You can cut out the rusted area and weld in a doner piece or even make one yourself. Just what a video of Jesse James making a gas tank on TV and start banging away. You can get it perfect I did!
In my humble opinion as an Architect the bumper shock suport does add to the structure in that area, I wouldn't remove it"
Old 01-23-2004, 06:13 AM
Thanks for your help fellas,
The rust appears to have started on the outside of the car as the inner pannels are in great shape. Since i'm moving my battery anyways, I think I'm going to cut out the tray and take a peek underneath just in case, it looks clean but you never really know.
Still undecided on how I'm going to repair that hole in the above pics though. I suppose I'll need to wire wheel it all down and see how far the problem goes.
Keep the suggestions comming!
Adam
Old 01-23-2004, 07:55 AM
Chuck Moreland's Avatar
That is a common rust area, dirt collects on top of the bumper shock mount and it stays wet.
I'd cut it out and weld. If you really want it right, get a section. Else do your best forming sheet metal.
The bumper mount is not structural, except to hold the bumper. Early cars didn't have anything there.
Old 01-23-2004, 08:10 AM
The other area is the fender mounting seem. Doesn't look too bad, you can probably clean that up and treat with POR 15.
Old 01-23-2004, 08:11 AM
I think I'm going to drill out those spot welds and do the repair and leave the mount brackets off and see how it looks.
Thanks Chuck!
Adam
Old 01-23-2004, 07:44 PM
Glasgow 911SC's Avatar
Adam,
Any update on the repair? These pics always give me that sick feeling so it's good to see progress.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 02-23-2004, 12:01 PM
brawlins's Avatar
Adam - Your signature says "1978 911SC 3.0 (former)". Is this car with the rust an SC or was an SC your "former" car?
1982 Porsche 911SC Coupe
1999 Porsche 911/996 Coupe
Old 02-23-2004, 12:47 PM
How much stuff do you need to remove to clean above the bumper shock mount?
Old 02-23-2004, 12:49 PM
If you just want to clean the built up dirt out of there you have to take out the washer res.
Dean
Old 02-23-2004, 02:37 PM
Another question.
Is that rust repairable without removing the mount? Looking at the pic it seems the rust may go below the mount's (vertical) flat surface. I guess you could weld the new metal in from the other side if this is the case??
Chris
Old 02-23-2004, 03:34 PM
