Proper propane fill procedure on AC
All right guys, whoever out there knows all the tips and tricks to using Propane or Propane/Isobutane properly, please come forward and enlighten us. What is the proper way to put it in. The proper way to modify the nozles on the bottles (pics), the best ratios, the proper way to fill it, etc... For example, upside down or right side up (liquid/gas), and other things like that. Also, if there are any modifications that need to be made to the expansion valve, what needs to be done so that the evaporator core does not freeze up. Basically, if anybody out there has plenty of experience in this area, please give some pointers.
The 911 divided the world between those who could drive and the rest 80 930. 96 993 supercup. 95 993 gt2 evolution. 83 956. 89 Testarossa. 91 512 tr. 89 ur quattro |
Author of "101 Projects"
Aren't there plenty of better (non-flammable) alternatives out there?
-Wayne
Ed,
Steve W uses a Propane cocktail.... R12 Substitutes? Any one using them? Seems many of the alternatives are flammable. Including the popular Duracool.
Warren & Ron, may you rest in Peace. |
I'm off the hook.....
Most of the people that use propane or butane are in Tijuana or dead.
No, I don't sing. Based there for too long. |
Automotive Monomaniac
Is my "Freeze 12" fill flammable?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Actually Wayne, after much research, I have come to the realization that there aren't. Especially when one is trying to do the right thing for the environment. Not to mention staying cool. And for those that doubt the safety of the whole enterprise, go here www.greenchill.org. Look up the scientifical studies done on it. Very safe indeed. Though over here in the US, where fear is a hobby and dupont has influence, there is plenty of BS going around. While it can be considered dangerous in a theory, in practice it has been extremely safe. And for those that don't know, R134 is flamable under compression.
Friend of Warren
I don't know why it would be anymore dangerous than pressurized gasoline in rubber fuel lines.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Steve, I read that thing already. I need what that does not say. Like do you put the propane as a liquid or a gas. Invert the can or not. How has it affected the expansion valve? Do you need to tweak it to cope with the super low temperatures? Basically what I am looking for is how this applies to our cars. Oh, and how are your results?
Ed, my system works b*tchin. Gas or liquid, I don't think it mattered too much in my case. I screwed an ac hose adapter to the end of a propane torch tip with a pretty small hole drilled at the tip, and I think I put it in upside down as a liquid. Just don't flood it in as a liquid too fast. Also be aware that by weight, if a system normally takes 36 oz of r12, you only install about 14oz, (don't remember the exact weight conversion) of a propane/isobutane mix.
I drilled a very small hole out of the propane torch tip to open it up. A standard propane tip hole is smaller than a strand of hair, and I didn't want to wait two hours for the thing to empty. I also drilled out the check valve on the underside of the torch adapter. I removed the screw on flame shroud at the end of the torch, and retreaded the end to match the threads on my ac hose. I screwed one end of the hose onto the end of the rethreaded torch, and screwed the other end onto the low side ac valve. Turn on the torch valve to release the gas into the system. For isobutane, use about 20% by weight, and I used MSR's brand from Sport Chalet here. It is about 80% isobutane and 20% propane. The top of the can is pretty much identical to the tops of old R12 cans, so my old R12 ac adapter worked fine. Check the high and low system pressures after you are done to optimize. |
What pressures should I be chasing on the high and low side? They are probably going to be lower I presume. Probably lower than R12 and a heck of a lot lower than the usual 134 numbers. I gotta go find an old R12 hose. Somebody is gotta have one.
I don't really remember as I did this quite a while ago. It should be similar to R12 if you use a 80/20 mix. If I recall, on my truck, it worked well at around 210/35 high/low.
Sounds normal Steve. Are you having any problems with the evap core freezing up?
BTW, at the bottom of this link page is a chart of the EPA accepted and unaccepted refrigerants. Notice some of the ingriedients.
http://www.epa.gov/ozone/snap/refrigerants/macssubs.html#note5
Start by lighting up a cigarette...
[skip several steps] have your wife call 911 or just ignore my advise altogether!
Mike Searching for a new ride '04 VW GTI 1.8T RIP ![]() '76 911S 3.0 RIP ![]() http://www.pelicanparts.com/gallery/BanjoMike |
Admittedly, I am not a cooling system expert by any means... Are there any DIY articles out there for AC conversions? -Wayne
Steve, the reason I mentioned the evap freezing up, is that propane seems to cool too good and some people end up with outrageously low vent temps until the thing freezes up. But I guess that with the limited size of the condensder in the 911, that won't be a problem. I guess I have to try. I should probably clean the condenser anyway.
The 911 divided the world between those who could drive and the rest 80 930. 96 993 supercup. 95 993 gt2 evolution. 83 956. 89 Testarossa. 91 512 tr. 89 ur quattro Last edited by Ed Bighi; 06-02-2004 at 03:16 PM.. |
fascinating - keep us posted. What about using the Freeze 12? Would that be an easier fill??
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Ed, You make many excellent points. At the end it depends on who's lobbying who the hardest.
As mentioned before just about every R12 alternative (if not all) is flammable.
