Porsche Junky
Little help please.....
New member here....drinks on me....
I just picked up an 82 911 SC...schweet.....I pretty mechanical but this has me stumped. There were no turn signal or hazard relays in the car. I ordered my parts from Pelican and installed them. The turn signals now light up but do not blink!!! Whays happening here??? Thanks....... |
Bad flasher module?
Post pictures of your car. It is mandatory! Welcome, and congratulations.
'69 911 Targa w/ 3.2 |
Porsche Junky
Thanks...pix coming up....
![]() Flasher control module....... ![]() |
Possible you have a bad relay - even though it is a new one. Also - is it a 3 piun or a 4 pin relay? If it is a 3 pin, try a 4, if it is a 4, try a 3 pin.
Another possibility is you ahve a faulty turn signal switch. AFJuvat
Look for incorrect (single filament bulb in a two filament socket- two filament socket has two contacts in the bottom) or improperly installed bulbs in the turn signal housings. Jim
MAGA
I just replaced my turn signal flasher w/ a new one and it acted exactly like yours is. When I returned this I noted to the parts guy that my old
flasher was a Hella and that when opening it up it had a visible set of points in it, while the new unit was smaller and it appeared to not have a mechanical set of points in it. The new flasher was the right part number and it had the same markings on the 4 terminal spade connectors. Well he exchanged the unit for a Hella brand unit that he had on the shelf and bingo my signals and hazards work properly now! I did not take the new Hella apart to see if it looked different. Don't know if first new unit was bad, but it was obviously different inside. My car is a 79 SC
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Porsche Junky
Thank you thank you thank you....you guys are awesome. I will take this info to the parts department and get this done. This is my first foray into the 911 class, all my previous experience has been 356 class.....quite a change.....heres a pic of my new toy. 60k original miles and a creampuff......
Porsche Junky
OK....I went out and got a couple thermal flashers, made some jumpers and started poking around....I am very happy to report my interior lights flash on and off brilliantly now.......
![]() I'm going back out there, watch my back...... ![]() |
19 years and 17k posts...
Nice car! Congratulations!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Porsche Junky
Thanks AZ.....
![]() Tim...went out and found a Hella.....works perfect, Thanks.... ![]() |
