Stackett's Avatar
Will 16X6/7 or 16X7/8 Fuchs fit a 75 911S?
Subject 1975 911S
Question: Will 16X6/7 or 7/8 Fuchs fit without any body work? It's just the standard body with 15X? wheels.
Scott Tackett
_______________
1980 SC Targa (His)
1975 911S 25th Anniversary Edition (New addition to the family)
2003 VW Beetle Convertible (Hers)
(I'm not going through midlife crisis, I'm just reliving my childhood obsession!)
www.inhousenetworking.com/911/index.htm
Old 07-28-2005, 09:46 AM
Bill Verburg's Avatar
6 or 7 front is no issue at all
7 back w/ a 225/50x16 or 225/45 has been done
8 back only w/ 23.3ET 944 8s, same tires as above, more work to get clearance at the lips, but its been done.
Bill Verburg
Old 07-28-2005, 11:48 AM
Stackett's Avatar
I think the ones I have are 6/7s. I just can't remember. They are off of my 80 SC. I'll have to look at them tonight when I get home.
Thanks Bill.
Scott Tackett
_______________
1980 SC Targa (His)
Old 07-28-2005, 12:13 PM
I'm having 16x7 wheels w/ 205/50/16 tires installed right now. I'm told by a number of people it should work fine. I'm having the camber adjusted just to be sure. However, I'm also going as low as possible w/o it getting goofy. I'll post results early next week.
Old 07-28-2005, 12:16 PM
Hi Scott,
I have a 1975 911S and have agonized/experimented with the best way to get some wider tire without bastrdizing the car i.e. flares...
I run the stock 15x6 fuch in front with 205/60-15 and 15x7(911R) wheels in back with 215/60-15 with no problems whatsoever. For track I run 16x7 (951) from 1986 944 turbo on all four corners with 205/55-16 front and 225/50-16 rear. Note: I did have to "roll" the fenders in back because of rubbing on extreme corners and undulations in the road. Hope this helps.
Nick
911S/GTS4
964 C4
1987 Carrera 3.2
Old 07-30-2005, 06:12 PM
Banned
Jason Cullen's Avatar
Scott,
16x7's is about as wide as you can go on a narrow body car.
16x8s will not fit, unless they are 951 23.3mm offset Fuchs. Which run $600 to $800 a pair.
As far as tire size? 225/50/16 is too big - It will rub!!!
205/50/16 is a nice fit for 16x7's.
You should run the same size wheels on all "Four" - I would not stagger the wheel size.
Congratulations on your new addition!
Jason
Old 07-30-2005, 10:22 PM
marcesq's Avatar
On a '77 Targa:
For track use, I had 15 x 7s all the way around with 225-50s, rear lips rolled
Street set up was 7 x 16s all the way around with 205/55/16s, rear of car was set at 24 3/4, front at 25 1/4 with 16" wheel mounted.
When I put the track tires on the car was lowered by 1/2".
225/50-16s will not fit in the rear unless the rear flares are "worked" hard.
225/45-16s will work but only on 23mm offset '86 951 wheels (fuchs or phone dials). In fact you could run this set up on all corners, except no one makes a 225/45-16 R compound tire.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 07-31-2005, 04:40 AM
The answer-Yes!!
16x7 w/205/50/16
Image Hosted by ImageShack.us
Old 08-04-2005, 10:26 AM
Is it ok to run 205/50/16 tires on 951 16x8 wheels all around on a '71 with stock flares?
I think the fitment would be similar to this car with 8's and 205/50/16's all around:
According to the tire specs the 8" wheel is one size too wide for a 205 tire.
Thanks for the help,
-Kaefer
Old 08-04-2005, 11:20 AM
I think "8" wheels are too wide for 205/50/16 tires.
Here's a link for my tires. It specs wheel width between "6" and "7.5".
205/50/16
Old 08-04-2005, 11:42 AM
205/50/16
I agree...sort of. Check out cmc140's car in the middle of the following page:
Is it just me, best looking 911 is 74 to 77?
Those are 205 tires and they look like they fit 8" wheels pretty well.
Old 08-04-2005, 12:04 PM
evill's Avatar
The answer-Yes!!
16x7 w/205/50/16
Congratulations on the fit. Your car looks GREAT. How about posting some more pics of the new tires and wheels from different angles for the rest of us narrow body guys.
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 08-04-2005, 12:17 PM
I am not worried with the 205/50's on the 8" rims. I was a little concerned when I had them put on, and I figured if they didn't fit properly someone would have said something. I think the reason they don't look goofy is because the Toyo T1r tires have the rim protector. I have also done some parking lot tests and they are awesome. I was surprised. To get them under the rear fenders I had a friend machine about 1/8 of an inch off of the inside to change the offset and I had to roll the lips, and I am running 2.5 degrees of negative camber in the rear. No problems so far just way better handling.
Old 08-04-2005, 01:01 PM
Well there's no arguing with those results. Your car looks fantastic!
Old 08-05-2005, 03:35 AM
Thanks a lot sebring. It is truely amazing how good the mid year cars look with bigger wheels. It is unfortunate that know one makes wheels for these cars. I would think there would be a market. My father bought my car in 91 and it had 15x6's and 15x7's. I wanted him to buy wheels then, but he said he didn't think anything would fit. He was pretty much right. So, fourteen years later after I got these wheels (ebay specials, I bought 3 years ago) to fit I was estatic. All it took was a complete suspension rebuild and I had pretty much given in to the fact I was going to have to get SC flares put on. I'm so happy I don't have to have that done now. Now I think the narrow body is the only way to go.
Old 08-05-2005, 05:38 AM
PRE-H20's Avatar
15x8's Fit!
i have 15x7's in front 215-50-15's NO RUBBING AT ALL
i stuffed 15x8's in rear with 215-50-15 in the rear and NO RUBBING AT ALL, tuck in nicely, rolled fenders by a pro.
i like it.
lowered to 23 3/4"
Old 08-05-2005, 09:43 AM
Ed
Twist my arm. Thanks for the kind words.
Old 08-05-2005, 10:09 AM
evill's Avatar
Thanks Sebring, your car looks so different with the 16's on it. The 7's give wheel wells a fuller look, looks tough.
I may not flare my 77 after all.
Ed
Old 08-05-2005, 11:17 AM
sp_cs's Avatar
Cool
Sebring/CMC
IMHO, two of the best looking pre '89 911's i've ever seen on this website!
A fine effort on both counts
Cheers
SP
Old 08-05-2005, 11:42 AM
Sebring77........beautiful car
love the creamy white color, am thinking of getting mine re-painted to a pearl white.
My tires are 205/55/15.
gatotom
76-911s-sold went to motherland
13-A4 2.0T Quattro S
96-Chev 1500 4x4
88 Sabre 38 mk 2 sailboat
Old 08-05-2005, 01:29 PM
