2 fans?
hey guys a quick question. i was wondering how to test if the first fan works? I kno that when my temp gauge hits 3/4 mark, the large fan turns on.
2nd...does cleaning ur radiator (straigthening fins and taking out stuck pebbles) help overheating problems?
84' 944
Old 10-23-2005, 10:27 PM
Eldorado's Avatar
my rad is riddled with pebbles - and never goes above the first line during regular driving.
an overheating issue might be caused by one of those pebbles causing a leak in your system - how's your rad fluid level?
Kyle
Old 10-23-2005, 10:33 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I recently installed a new radiator in my 951 and noticed a perceptable difference in operating temperature. Might've been the new radiator, or the cooling system flush I did at the time, or the fact I'm now running pure H2O & water wetter. Or a combination.
Black Cars Matter
Old 10-24-2005, 07:35 AM
my radiator levels fine and there are no apparent leaks.
im running the same as porsche o phile, water and water wetter.
yea during normal driving it stays below 2, but stop and go is horrible and brings my thermo to the 3/4
84' 944
Old 10-24-2005, 07:29 PM
Wow you really are having problems with your cooling system huh. When your car is off, try spinning your fan blades by hand to makes sure they spin freely. If one doesn't move or is very difficult to move, the motor is probably toast. As far as hitting the 97 degree mark, it seems to be very common on the early cars. The stock thermofan switch tells your fans to turn on at 92 degrees, and sometimes the engine can get a little hotter before this happens making it get close to the 97 degree mark. If you only have one fan working and you are in traffic, it will be much harder for your car to bring it back down below 87 (or 89 I cant remember) where your fans turn off. If you drive in traffic a lot and live in a warmer climate, you could consider putting in a low temp thermofan switch and thermostat. If your thermostat is bad as was mentioned in your last post, your car will not be able to cool down easily as your coolant will not be circulating at the proper temperature. If it opens up at too high of a temperature, your car will be operating at a higher temperature than it should. Are you still having the low temperature issue that you mentioned in your last thread?
'84 944, '05 GTO
Old 10-24-2005, 08:09 PM
yea like in the mornings, i drive directly to school not much stopping, if there is, its just a stop sign. the thermo never goes above the middle of the left box (very cold). even during warm days when im constantly moving, it usually never goes above the first box, but stop and go traffic jumps my thermo really fast, and my aux fan is constantly turning on.
how much are new thermo fan switches? thanks
84' 944
Old 10-24-2005, 08:27 PM
I really dont think that is your problem. I would be on top of checking out my fans and that thermostat if I were you.
'84 944, '05 GTO
Old 10-24-2005, 08:49 PM
okay thanks
84' 944
Old 10-24-2005, 08:55 PM
Tapage's Avatar
Send a message via ICQ to Tapage Send a message via AIM to Tapage Send a message via Yahoo to Tapage
check this out first ..
http://www.clarks-garage.com/shop-manual/cool-08.htm
David Alonso De La Vega Tapage
Panama
944 Turbo
Old 10-25-2005, 11:00 AM
so if my engine doesnt warm up when im moving constantly..u guys think my thermostat is broken?
84' 944
Old 10-25-2005, 01:19 PM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
Make sure the system is bled properly also. warm up the car and crack the bleeder open just a little and make sure it's getting all liquid and no air out before you close it again.
The thermostat is a PITA to change. The snap ring is big and tough to work with. Use a 90 degree end snap-ring pliers to get it off and just have at it cause it's a stubborn thing!
When you replace it, go with a 160/180 degree unit. Lowest temprature one I found was at NAPA and it works great - temps stay below 1/2 on the hottest days!
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 10-25-2005, 01:28 PM
does it hurt my engine if i have a faulty thermostat?
84' 944
Old 10-25-2005, 02:05 PM
Rmills944's Avatar
not unless you're running too hot
Ryan
Old 10-25-2005, 02:13 PM
Tapage's Avatar
I'm with you .. the most easy test is bleed your cooling system before buy anything ( thermostat ) if is not necesary ..
Panama
944 Turbo
Old 10-26-2005, 06:34 AM
by bleeding the syestem do you mean opening the coolant cap just a little?
83 944na
Old 10-26-2005, 08:32 AM
Tapage's Avatar
just doing this you get air on the system ..
You must do that with the engine at normal temp running and with the proper bleed fitting ...
Panama
944 Turbo
Old 10-26-2005, 03:12 PM
Nope, to bleed your system you must open the little bleeder screw located where the upper radiator hose connects to the cylinder head. Below is how the shop manual says to do it. Although for some reason i think the arrow they marked is pointing to the wrong one. If my memory serves me correctly, it is the one where I drew the yellow arrow to. You will figure it out once you get in there. Just don't over torque the bleeder screw when you close it up.
'84 944, '05 GTO
Old 10-26-2005, 06:37 PM
