RS pulley
single sheave
![]() Triple sheave double sheave
That's on my to do list one of these days...
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
I have my mechanic converting my 90 3.6 to a single pulley setup at this time. My main motivation is improved reliability (avoid possible bearing seize) and ease of replacement. I shredded an alternator belt at my last track event and it was quite tricky to replace.
There is a rumor that this conversion increases engine output, but it seems to me that the same load is present: both the fan and the alternator are still being turned.
Kris 1990 C2 2005 CS http://krisu.smugmug.com/Auto/Porsche |
The alternator now runs at the slower fan speed, the result is slower charging rate of the battery
The solution for shredded fan belts is a serpintine or the Smart Racing dual set set up.
My mechanic took a slightly different route: Patrick Motorsports makes a part that locks the two shafts together so that the fan belt also turns the alternator. This appears to be a minor variation on the RS theme.
I still have the triple on the bottom; swapping to a single requires partially dropping the engine so I will wait until I need to do that for some other reason.
The lower 964 pulley incorporates the harmonic balancer, your crank will love you for leaving it alone.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 11-14-2006 at 07:29 AM.. |
That being said, I can't see single pulley parts for either 964 RS or 993 RS in the ROW PET. Am I reading PET wrong? Quote:
One concept on some of the race cars out here with high displacement motors: use an alternator from an earlier car. My 3.8 is set up this way. No need for the hefty 946 or 993-sized alternators on a race car. With an earlier alternator, you use a conventional 911 fan shroud, fan and pulley. You can use the 993 crank pulley or the Patrick unit. Works great.
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
Anybody have a dimensioned drawing of an RS pulley?
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900 |
Is this the part number for the RS version? Any other parts needed?
993.106.051.80
The RS parts are
993-106-051-80 impeller hub for the alternator 993-102-050-40 pulley for the crankshaft
- is the factory hub still a viable option?
Bill - did you disconnect the fan breakage sensor? I managed to break mine when I pulled the fan to swap to the RS Pulley.
Yes, you don't need it any more as the alternator light will come on if the belt breaks
Mine's finally in.
Tyson helped to pull the fan off the alternator. So a couple of weekends ago I installed the alt/fan back into the car. Then I pulled one of my all time great moves - snapped one of the studs holding the pulley on. Poo. The local "has everything" hardware store actually had M6 automotive studs, but either way to short or too long. So I took a 50mm M6 bolt and cut off the head. Used a little blue locktite to just make sure. And bolted it all back together (again): Got to use my new handy-dandy belt tensioner from Napa. All running good so far. Nice to have it in: one less belt to break and much easier to change trackside just in case. I did think of pulling out the other two studs and re-using the Allen head cap screw, but liked the ability to use a 10MM socket. Anyway, I drove it around a little to make sure all was good - now time to put on the SS brake lines...
