Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Question Bilstein front shocks ?
Hi,
Please help me with this:
My father bought on ebay a pair of front bilstein shocks at $ 100.00 usd that I already have on my hands. But I´m not sure that this shocks are Bilstein.
The shocks cames in a Bilstein box that says on hand writing 73-89 911 or 75-84 Turbo.
I have the doubt that this shocks are Bilstein because don´t say the brand and the color is like polished aluminium (the other bilstein shocks that I have are yellow with blue and I know that exist greens and black).
The shock are gas operated and the serial number is :
5195001H002 (housing)
B36-556A-9 ( looks more than bilstein numbers, this are in the plastic or mounts )
I can´t find the serial number in the bilstein web page but I saw that exist diferent shocks for diferent struts (boge,bilstein,koni)
I want to use this shocks on my 914 with 74 911 front supension.
My question are:
1.- Do this shocks are Bilstein ?, if not what brand are ?
2.- My struts are original, then are boge ?
Let me know
thanks and regards
1972 914 914-6 gt look chevy 2.8 v6 (928 engine project)
1974 914 916 Look (3.2 webers engine project )
1984 944 Auto
550 Spyder (replica) 914 side trans 2.2 type 1
1957 R50
1981 R100RS
2000 K1200RS
My Page
Old 10-04-2002, 12:58 AM
If knowledge is power then in this case don´t have the knowledge is be stupid !
In this moment I feel like !
For saving some bucks, I will need to spend a lot more to can use it.
I already call bilstein and ask for this shocks cartridges:
1.- Yes, it´s bilstein !
2.- But only can be used in bilstein shocks cartridges covers a with bilstein struts.
I believe that my struts are boge ?
Can somebody please tell me if can adapt this cartridges to boge covers ?
let me know
regards
Old 10-04-2002, 04:38 PM
Stay away from my Member
campbellcj's Avatar
From what I recall, there are Bilstein inserts available for the Boge (black) struts; but, it's a different part than the one for the Bilstein strut.
This is from memory and might be wrong - if you don't get a definite answer I have a Bilstein catalog in the garage that might have the info you need.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 10-04-2002, 04:47 PM
campbelcj:
Thanks, I wil apreciate
Regards
Old 10-04-2002, 07:20 PM
campbellcj's Avatar
My Bilstein catalog doesn't list B36 prefixes for any Porsche! So I don't know what you have there. (The box usually has a part number on it somewhere.)
For a 74 911 the options are R36-5001 (HD) or RE3-5050 (Sport) for a Bilstein strut, or for Boge struts P36-0112 (HD) P36-0113 (Sport) or P36-0115 (Rallye-Sport).
Chris C.
Old 10-04-2002, 10:11 PM
Those are Bilstein inserts for Bilstein shock housings. Won't fit a Boge housing. I know, since I was sent these once incorrectly instead of the correct ones.
Old 10-05-2002, 07:03 AM
89911
Wayne
Thanks for your answers.
I will bought a game of boge shocks to finish this 911 suspension conversion.
And I store this cartridges until I upgrade my other 914 to 911 suspension this time with bilstein struts
regards
Old 10-05-2002, 10:29 AM
fred cook's Avatar
Cool Bilstein Strut Inserts
Those appear to be the Bilstein inserts for the Bilstein strut bodies. If you look, you will see a small machined ring near the end of the small rod. These inserts are held in place by a roll pin that catches the strut rod at this machined area. The inserts go into the struts "upside down" so that the threaded rod on the big end is the part that goes through the adjustable mount that attaches to the car body. There are two bearing surfaces in the strut housing that the large cylinder actually bear against. They could be either Heavy Duty or Sport (heavier) inserts.
Good Luck!
Fred Cook
"80 911SC
Old 10-06-2002, 11:58 AM
