Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
99 Passat Clutch Issue after New Install
Hi Everyone,
I recently installed a new clutch on my 99 Passat 1.8T using the directions here, which were amazing BTW!! Yet, I am having an issue that I am hoping you all might be able to help me with.
After the install and bleeding process, when I started the car, there was a loud ticking sound coming from the engine/transmission area, which was not there before. It seems like there is something hung up on the flywheel (that shield maybe that is between the engine and trans??) and is causing the car to want to die because of the pressure being placed on the flywheel.
Anyway, it looks like I need to pull everything apart and try to figure out what happen during the installation process. If you have any ideas, please let me know.
Thanks,
Angel
Old 05-14-2020, 10:54 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hey Angel - welcome to the forum and glad to hear that you found the tech article to be useful. I would pose that question underneath the tech article in the Comment section and one of our techs will be able to respond to it and give you some feedback. In the mean time, it's a good idea to reinstall everything to see if there was a piece that wasn't secure - hope it gets addressed quickly.
Let us know if there is anything else that we can help you with.
Thanks!
Old 05-14-2020, 11:54 AM
Tags
clutch , passat , transmission
