Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
low boost
newbie here.
2003 a4 1.8t. keep getting a 16683 boost not reached code. Replaced the diverter valve with no change. Will be fine for a while then trip a code again. Hoses seem ok. Is there a way to smoke test the boost side? I assUme any vacuum line on the manifold would work.
Juggling multiple vehicles with issues right now, hoping this will be any easy one
tia
Old 08-02-2022, 01:38 PM
Check your boost pressure Valve. it sits next to the front of the turbo and goes into the intake boost
1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*.
1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother
1983 944NA Gave to my Dad for being Awesome.
Old 08-07-2022, 09:36 PM
Finally got around to doing anything. I replaced the boost sensor and the hoses attached to it. one had a small tear. It's still not making more than 10psi and is slow to build. It used to hit 15 with no problem.
Any other ideas?
Old 11-06-2022, 05:52 AM
Got a smoke machine. Hooked it up to the intake manifold, the air filter snorkel and one of the tubes that goes from the air filter snorkel around the back of the motor. Got no smoke leak anywhere.
any other thoughts? tia
Old 11-07-2022, 08:52 AM
