Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
1983 VW Rabbit Convertible
With headlights on, the tachometer and clock do not work. Any ideas or suggestions.
Thank you for any input.
Old 02-13-2025, 11:43 AM
I recommend Check all of your grounds that are under the dash above the fuse block. Make sure they are clean. Also Check any grounds in the engine bay. From my own experience, with my 87 Cabriolet and my 82 924, was always ground issues that would be the problem creators .
1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*.
1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother
1983 944NA Gave to my Dad for being Awesome.
Old 02-17-2025, 09:11 PM
Thank you for replying to our post. As you suggested I replaced battery, ground cable to chassis, and ran a new cable from the engine block to chassis. Took the gauge cluster out and replaced the voltage stabalizer. I still have the problem with tach not working when headlights are on.
I checked the voltage with the headlights on and it is 13.8.
Old 02-26-2025, 01:51 PM
