| Registered Join Date: Jul 2009
				1983 VW Rabbit Convertible
			With headlights on, the tachometer and clock do not work.  Any ideas or suggestions. Thank you for any input. | ||
|  02-13-2025, 11:43 AM |
| Registered |
			I recommend Check all of your grounds that are under the dash above the fuse block. Make sure they are clean.  Also Check any grounds in the engine bay.  From my own experience, with my 87 Cabriolet and my 82 924, was always ground issues that would be the problem creators .
				__________________ 1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*. 1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother 1983 944NA Gave to my Dad for being Awesome. | ||
|  02-17-2025, 09:11 PM |
			Thank you for replying to our post.  As you suggested I replaced battery, ground cable to chassis, and ran a new cable from the engine block to chassis.  Took the gauge cluster out and replaced the voltage stabalizer.  I still have the problem with tach not working when headlights are on. I checked the voltage with the headlights on and it is 13.8. | ||
|  02-26-2025, 01:51 PM |
