97 A6 quatro wagon draining battery
Drains battery nothing on pulling 3.6 amps. Noticed can turn radio on and off with out switch on. Pulled ignition switch still pulling amps and radio still works. Pulled all fuses nothing changed.
My 03 a4 qt drains a battery in a fairly short time if left unused,lots going on even when not running.
Have you had any aftermarket items added that may be causing this?do you have the right size battery for instance,lots of causes for this problem afterall.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
No after market parts. Have pulled fuses. I now have console with radio and climate control instrument cluster all unhooked. Still have a drain. this car is not in perfect condition but it does its job.
