Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
Ellie (guest)
Guest
Posts: n/a
No comment here, but a question looms my mind, a 2003 A4 3.0L mileage on it is 126,000 and the timing belt broke, knowing it is an interference motor, what are the chances of a bent valve? Should I take a chance with a timing kit, and hope for the best? Is there a way to check for bent valves?
This post was auto-generated based upon a question asked on our tech article page here: Audi A4 1.8T Volkswagen Timing Belt Replacement | Golf, Jetta, Passat & Beetle | Pelican Parts DIY Maintenance Article
Old 02-08-2017, 10:05 AM
I'd say you have a 97% chance of bent valves. It is not really possible to check for bent valves while the timing belt is broken.
- Casey
uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
The 3.0 has a timing chain does it not? You can't break that unless you run the.engine without.oil. The 1.8L has a timing belt.
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 02-27-2017, 07:27 PM
