View Single Post
Porchdog Porchdog is online now
Castings would be essentially to size, just requiring clean up and polishing. Pattern making for the casting would be the greatest cost. If you are supplying a sample they can probably cast a resin pattern from it, which could be a bunch cheaper.
Since they were originally cast the sample will already have draft - the pattern guys will just need to add a sprue and vents. For that matter they might just be able to use your part for a pattern. There are still small foundries out there doing custom work.
They might even lost-wax cast a part like that - for the size I expect that would be more expensive.
There are also casting houses out there 3-d printing patterns. Since you have a sample I suspect that wouldn't be a savings.
I can model one of those for you. The cheapest 3-d printing is likely by Shapeways or a similar company. We have found found good strength with their "Strong and tough" plastic. I wouldn't be surprised if they want $400. each for those - but you pretty much need to submit your model and get a quote.
3D metal printing is still pretty expensive especially for something that large.
1981 911 SC
2013 Mini Cooper JCW
2017 GMC K1500
Old 05-11-2018, 03:35 AM
