Angry '99 328is abs/speed sensor wire burn
Ok so I have a 99 328is and had a wire burn up behind the glovebox. Checked it out and was told after the burn that the abs module has no power and that a speed sensor is out. If anyone has any ideas on how this may have happened and how to figure out the wiring diagram for this problem so I could perhaps run a new wire I would be much appreciative. The abs and traction control light appeared along with check engine and airbag on the dash.
Old 03-07-2011, 09:42 AM
Tags
abs , dash lights , electrical , traction control
