89 325i heavy jerking
89 325i. 5speed. Jerks almost as if the rev limiter is on at 3000 rpm and above except a bit more sporadic in the way it is cutting out. Idles nice. Has normal power otherwise. Changed the fuel filter. Checked plugs/wires. Checked fuel pump. Scanned reads IC. Any thoughts?
Update. After several tests I found the problem... Crank sensor wire had a run in with the radiator fan. Was slowly shaving the wire away. Replaced the sensor and all good.
