View Single Post
wswartzwel wswartzwel is online now
unsafe at any speed
wswartzwel's Avatar
It may be a DC motor. Check the brushes to see if they are worn away and not making contact with the commutator. should be a small cover on top of the motor to access the brushes. Testing the DC voltage output from the Rectifier may also tell you if you are losing voltage after 15-30 seconds. Floor buffers use a similar system, I have seen them fail due to the winding in the armature breaking and losing connection. an armature for one of those motors is sometimes more expensive than it is worth.
Bill Swartzwelder
Old 12-13-2018, 06:57 PM
