If it is an AGM i do not understand the issue. Set on the AGM setting. If it’s not smart enough to go from a low charge to a maintenance float charge I would look for a different unit.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
