View Single Post
stevie 77 930 stevie 77 930 is offline
stevie 77 930's Avatar
This has been an exercise in patience. I had to wait 3 weeks for USPS to deliver these 930 calipers. Yes this is the wrong caliper and that's why I mounted it upside-down. The correct caliper is still being cleaned in the ultrasonic tank. I didn't use the 930 caliper spacers ( 930.351.581.01) as others have done. Instead I used 4.4mm thick washer from the hardware store (way cheaper). Also with the 951 rims I didn't have to add spacers between the hub and the wheel. This also means that the rims I just got back from powder coating can't be used. These are the newer caliper design with out the banjo fitting. Not sure I I have to back date the calipers
Dave, you're good on the fronts. The factory brake-lines for the front caliper to the flex hose is all you need on the fronts. The rears area different story....
1983 911SC
1974 914
2018 GTS
2019 Audi S4
'76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 12-24-2020, 07:05 AM
