View Single Post
WolfeMacleod WolfeMacleod is offline
Update:
Quickjack support has had me remove, clean, and blow out three different valves, swap the hose fitting on the power unit, try each hose on each fitting, and flush the unit by holding both up and down buttons for 10 seconds.
Problem still persists. Won't even hold my own weight without sinking. And as one side sinks, the other side rises. Hadn't notices that before, but that doesn't seem right unless a control unit valve is borked.
They're sending me the following:
1 safety arm assembly
1 double threaded rod
2 nuts
1 cam
1 spring pin
1 male power unit fitting (one of those fitting had a center "plunger" that seems...sticky.)
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 12-16-2021, 11:11 AM
