You say the sound is coming from the rear of your car? Do you think its clutch related...or just "jerk related?" In other words, when you're smooth on the clutch, the sound does not happen, but if you're a bit more strident with it and/or the accelerator pedal, you get the sound...and its from the rear. Sound right?
Hmmm...could be CV joint related? Or something simple like the CV bolts backing out? Maybe something loose back there...like parking brake components? Possibly a loose exhaust hanger or heat shield is clanking away when the car is "jerked around?"
Re-reading your post, it does sound more clutch related. But does it happen even when you are not shifting between gears? Something involving the shift rod linkage over the tranny? Am trying like heck to avoid suggesting that it could be something inside the tranny. But have you checked your tranny fluid level recently?
