View Single Post
Alan L Alan L is online now
Alan L's Avatar
The other thing to check is the piston land clearance. If you re ring and deglaze etc there will be more friction/grip on the cylinder and piston rings. If the land clearance is out of spec you can get yourself in trouble going that route.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-06-2024, 08:06 PM
