View Single Post
Paulporsche Paulporsche is offline
Designer King
Paulporsche's Avatar
Motor Mount Question
I bought the Rennline HD engine/transmission mounts from our host, and I'm planning on installing them this spring. As many of you may know, they are inserts only, which go into the football shaped steel supports that bolt to the chassis. They slip into the supports from the top and bottom.
My question is regarding the existing factory ones that I'll be removing. Are the inserts of these mounts easily removed? Do they come apart similarly to the Rennline HDs? Is the easiest way to remove the inserts a matter of cutting the rubber part with a knife? Or must they be pressed or burned/melted out?
Thanks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 01-20-2025, 12:07 PM
