View Single Post
mikedsilva mikedsilva is online now
Originally Posted by 85RedCarrera View Post
After they were all torqued down, I can see a faint amount of flattened red o-ring barely emanating around the perimeter of at least half of the chamfered washers, where the o-ring is smashed between the unchamfered hole in the case and the chamfered washer….
I am concerned about this, but perhaps this is a normal deformation of the o-ring on this side of the bolt? Hard to believe, as I have never in my life installed an o-ring that was supposed to flatten out squeeze all the way to the edge of the washer.
Is this normal??
No.
This isn't normal.
Washers are bevelled on the inside so even if the case is not chamfered, the o rings should be contained inside the cavity of the washer chamfer.
Remove one of the washers that you can see the red? o-ring squished out, and take some photos for us here.
Always learning.
www.aircooledporsches.com.au
Old 10-05-2025, 10:47 PM
