Originally posted by patkeefe
Goran:
I am always impressed with your inginuity. However, I am a bit concerned at the interface from the spring plate to the ball. You basically have a threaded rod holding all of this together, and this may become fatigued. Did you do any stress calculations on this beforehand?
Pat
Peak shear forces on bolt are much much lower than what bolt should handle. But of course, those threads will eat themselves into sleeve...you are right. We'll check up on this!
Interscope 935 rear suspensions pickup (off Gunnar racing site):
As Chris said, nice thing with uniball rear suspension is that you can set camber and toe independently from each other.
This is ERP-version:
