You only need the one wire to the center of the O2 sensor. This is the one that goes to the orange connector on the firewall.
The others are for a pre-heating element. Not necessary except to pass smog tests in some states.
Check that your shifter linkage on the trans is connected properly. Also the pin that sticks out the side of the shift lever will wear.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
