View Single Post
lisa_spyder lisa_spyder is offline
Just a big kid really...
Katie,
I SAY RUN, RUN AS FAST AS YOU CAN!!!!
But you're not gonna; are you?! Hell...I'm not so old that I don't remember kid!
If you're going to pursue this, then look closely at:
inside the doors and into the rear of the front guards; that rust on the front guard screams "warning" to me. you won't be able to see as much as is really necessary without removing the front guards, but have a good close look on both sides of the car.
We've seen more than our share of these cars with rusted out A-pillars; the only external indication of which has been rust on the top of the guard and/or scuttle like what's in your pic.
Get the car on a lift and poke around the undercarriage with a screwdriver; particularly under the battery boxes and across the front X-member.
Pull up the rear mats and have a close look as well.
Get a compression and leak down test; at least the tacho has been changed to signify a more appropriate redline.
The engine doesn't look well cared for at all - signs of what appears to be corrosion on lots of bits.
There's lots more; the guys can point you in the right direction - gotta do some work!
Cheers,
Lisa
PS - look at the brightwork strips under the rear quarter windows (if they are there); right at the front edge where the rear of the door closes. If they are damaged it is a sure sign of prior accident damage of no small proportion.
Lisa Gregory
www.spyderautomobiles.com.au
blog: http://spyderauto.net
Old 02-20-2007, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #167 (permalink)
