View Single Post
bob barnes bob barnes is offline
Andy,
Stromski Racing sells some cylinder hold downs that can be used to ensure the 730 is squeezed to its minimum on the base gasket, sealing the cylinder to case and allows the heads to go on at a later date. Two per cylinder would be reccommended. I've never had a oil leak in this area in nine years. As you know, you purchased the tube in hand because the main purpose was the case sealing operation and cam tower to heads. I would hestitate to spend the money just for the cylinder.
Bob
Old 04-18-2007, 01:14 PM
