View Single Post
1972_911T 1972_911T is offline
1972_911T's Avatar
Originally Posted by Eagledriver View Post
Stock SC motor with carbs and exhaust will yield 220-240 and bolt right into your car. Minor changes for carbs and ignition are all you would need. A 3.0 with euro pistons and 39mm ports can put out 245 with 46mm carbs and good exhaust.
-Andy
What Andy suggests above has the obvious advantage of being far simpler to fit to an early car than the later 3.6 engines and wouldnt be too far from your goal HP in your early car this would still be lots of fun. This is prettmuch the route im going for my 72, 3.0 with 9.8:1 cr pistons, dc 20 cams mine will be twin plugged however and run on MS EFI.
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 12-26-2007, 09:14 PM
