View Single Post
911pcars 911pcars is offline
Rob,
Not sure about a '70, but the yellow wire from the ignition switch goes directly to the starter solenoid. In that there's another yellow wire in the engine compartment isn't necessary to energize the solenoid.
You can confirm the solenoid and starter operates by temporarily connecting a jumper wire from the battery cable at the starter to the #50 wire terminal on the solenoid. A remote starter switch makes this temp. connection less intimidating from 4' away. Don't forget to shift into neutral and chock a front tire.
Sherwood
Old 04-20-2008, 02:05 PM
