View Single Post
k9handler k9handler is offline
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Originally Posted by bell View Post
ok......if you unplug the rca's at the amp does the noise go away?
if so pull the radio out and take a piece of wire and hook one side up to the ground shields on the rcas , and the other side of the wire you want to touch the chassis of the radio, it'll either get louder or softer, if noise goes away secure the connections and you're done.
if not try connecting it to the ground wire of the radio.
if not then try only having the center pin of the rca connected to the radio and the ground shield not connected to the radio (barely plugged in) if this fixes it then either carefully strip and disconnect the ground shield of the rca and secure everything up....
what we are doing is redirecting the ground path of the rca's to where it won't be picked up by the amps preamp section. you're in good hands......we'll figure it out
ok I will do some testing tomorrow, thanks.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 05-04-2008, 09:51 PM
