Thread: Windsheild seal
View Single Post
halbl halbl is offline
Conrad, you are leaking somewhere. I would have an installer re-set it. They use a 1/4 inch bead of sealer. BE SURE TO REPLACE THE PLASTIC PINS FOR REATTACHING THE CHROME TRIM, BEFORE THE GLASS IS RE-INSTALLED. I watched the installation. Note, the trim is put together and laid in place and then gently pressed to the clips, almost simultaneously. Good luck. Hal
Old 11-29-1999, 02:08 PM
