View Single Post
Henry Schmidt Henry Schmidt is online now
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by johnman001 View Post
I agree that keeping it basically a stock 3.3 and freshening it up with new bearings, rings, rods, bolts etc. should give me what I am looking for.
If I do this, is there any easy mods to give slightly better performance?
Once upon a time I had heard that SC cams would wake up an otherwise stock turbo. Later I had heard of using other cams to do the same thing.
What cams would be recommended for a stock 3.3 Turbo?
I have always liked the SC cam for driveabilty.
You can open the intake to 36-37mm, cross drill he crank, upgrade the turbo and jack up the compression slightly. Of course better head studs. Twin plugging is an option if it's in your budget. Do all this and turn up the boost and 350 hp is an easy target.
At this point the trans becomes a critical issue. Trailing arms and chassis mods also become hyper important with all this torque.
I will add pictures of the intercooler and muffler tomorrow.
Cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-23-2010, 07:11 PM
