Originally Posted by Cocacolakidd
I have a pair of Adapters/Spacers (With built in studs) that are 25mm - would these work for you ??
The Adapters are almost new...I put them on and drove around all day to find out I really needed 1/2" or 12.5 mm Spacer/Adapters instead. The smaller size was because of my larger tires and rims on the back, to keep the tires from rubbing on outside fender-well. The Spacer/Adapter are Solid Billet Aluminum, hub-centric, 5 on 130mm spacing, and 32mm stud length off face. They will fit almost all Porches.
Have pfun...
I can use these if they are still available.
