Received my E-bay Digital Scale and for pre 1980 Parallel Window Regulators the weight savings by going with Manual Regulators is 2.6 Lbs per side for a total of 5.2 lbs. That is the weight of the Manual regulator (4 lbs) v. the weight of the Electric regulator and the electric motor (6.6 lbs).
Jeff The only 26 mm pivot pin replacement that PelicanParts carries that has a screw in the bottom does not match the configuration of the pin in my regulators. My regulators have the rectangular base going east /west with the slot going North/ South. Do i get the pin without the screw and drill/tap one in, or does the 90% difference make a difference?
