Its an 87'. I dont think its a fuel pressure issue. It runs very strong and normal until it decides it wants to die. I put the dme in my buddys 944 and it ran fine. so its not that. its not the vain air sensor either. I dont think it has anything to do with the battery because the only thing i loose is the engine. radio, lights, and everything on my dash works fine. On the sensor connectors, the plastic is very brittle as i think they are the origional sensors. is there any way to check if the wires are still connected inside?
