What would Darth Vader do
The bleeder is not on the head itself but hopefully in the 1" hose going to the top of the radiator to the top of the block. If there is no bleeder, you need to purchase the Bleeder hose or retrofit it to the later metal elbowed bleeder. There needs to be some way to bleed the system. A good bleed should take about half an hour (---> with the heater controls turned on - not the fans but the heater valve itself) Kamikazee, what year is your car?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
