View Single Post
kaw man kaw man is offline
83 944 run in start position only
I have a 83 944 that runs only when key is in start position. I replaced the ignition switch, speed and ref sensors and temp sensor and dme relay. It has good spark, 30 psi fuel pressure. When running in start position, the noid light at the injector blinks bright. when key is released to run position the noid gets very dim and the engine seems to wind down until it dies. All grounds have been checked and cleaned. With key on and all injectors disconnected it has battery voltage on one term. and 10.4 volts on the other term. i hope someone can help. Thanks
Old 10-14-2014, 05:13 PM
