Originally Posted by porsche4life
Does it still wind true and can you make do with the external monitor? See if you can collect from UPS and use it as is!
I would use my external monitor anyways.
Well... it's semi-operational right now. It'll power up, I can log into the machine and create a test winding program. The traverse mechanism however is borked. Initially, it worked for a few seconds... then it made a noise, moved erratically, and stopped working.
The traverse operates on a ball-screw mechanism powered by a motor...
I'm wondering if the ball-screw got bent...
