View Single Post
Hunt3R Hunt3R is offline
Hunt3R's Avatar
Sounds like it's working fine. 1 bar on the dash gauge is approx 0.4 liters. So add small amounts like you did, 1/2qt, drive it, and then check it again the next morning after it has sat overnight and see if you're up to full yet. If you're just 1 bar under full then be careful how much you add because you dont want to go over and have to drain some. But if you do, just remove the filter and empty it out.
Old 06-18-2015, 05:48 AM
